Logo
What can we help you with today?
Restarting RexCore runtime module
Last updated on 09 Mar, 2020
There are situations when you need to restart the REXYGEN runtime core (RexCore) on the target device. You can do so by running the following command in Linux terminal:
sudo systemctl restart rexcore
Check if RexCore is running:
systemctl status rexcore
The output should indicate that it is active:
● rexcore.service - REXYGEN Runtime Core (RexCore)
   Loaded: loaded (/lib/systemd/system/rexcore.service; enabled; vendor preset:
   <strong>Active: active (running)</strong> since Fri 2018-06-01 15:23:07 UTC; 2min 41s ago
 Main PID: 511 (RexCore)
   CGroup: /system.slice/rexcore.service
           └─511 /usr/bin/RexCore -l -c /rex/rexcore/rexcore.cfg
If it's not, your algorithm is probably making it crash and you need to remove all the binary files of your project:
sudo rm /rex/rexcore/*.rex
Afterwards you can restart RexCore again:
And check that it is running:
If it is, you can go back to your original activity.
Did you find this article helpful?
Previous
General information
Next
